John_Admin
_How to disable Epson Status Monitor in Windows 10
To disable Epson Status Monitor utility under Windows 10 follow instructions here :
Click on Search the web and Windows
Select Devices and printers
Select Your printer and right click on Printer preferences
Select Maintenance Tab
Check Disable Epson Status Monitor 3 box
I tried this but I'm still not able to bypass the issue at the printer. Just keeps telling me it does not recognize the cartridge. I changed the setting on my laptop. Restarted the laptop and printer and the printer is just stuck at the error msg
I am using WF-3720
Hello everybody,
i was following the instructions of John_admin and my problem is that i don't see the "Disable printers status monitor" button.
May i missed something. Or i dont have enought permission. Or the company 'Epson' patched this in the latest software update. I don't know.
I hope to find help here. I really don't want to buy another printer for 450EUR.
Regards
ASU
Hello John,
I want to reset the WIC-"waste ink counter" but I didn't find the "speed and progress"-button as shown above.
I tried to use the software to reset the WIC but it tells me to manually disable the "printers status monitor 3".
What are the next steps I can do to use the software to reset the WIC?
You can disable processes from WIC:
1. Start WIC as administrator.
2. In the main menu select `Support > Disable Processes`
3. Disable all lister processes and services.
4. Restart the printer and try to reset again.
Good day.
Please, reinstall the driver and make sure that you are not using limited account.
If this does not help, you can use WICReset to disable epson processes:
You will need to download and install WICReset then start it as administrator and select in the main menu `Support` > `Disable processes`.
