103 posts in this topic
If You have new printer models not supported by WIC utility or Your printer has new main board and it can't be modified by WIC utility - You have to use this solution. 100% working for  this printer models for making printer chiplesss - no ink firmware.
https://www.2manuals.com/index.php?cPath=107
Supported models:
XP-55, EP-306
XP-211, XP-212, XP-213, XP-214, XP-216, PX-046A
XP-230, XP-231, PX-048A
XP-235
XP-240, XP-241
XP-243, XP-245, XP-247
XP-255, XP-257
XP-340
XP-342, XP-343, XP-355
XP-352, XP-355
XP-430, XP-431
XP-440, XP-441, XP-446
XP-442, XP-445
XP-452, XP-455
XP-630, XP-635
XP-640, XP-645
XP-760, EP-807A
XP-830
XP-960
XP-6000
XP-8500
XP-15000, EP-50V
WF-2630, WF-2631
WF-2650, WF2651
WF-2750, WF-2751
WF-2760, WF-2761
WF-2830, WF-2831
WF-2850, WF-2851
WF-2860, WF-2861, WF-2865
WF-3720, WF-3721, WF-3723, WF-3725, PX-M680F
WF-4630
WF-4720, WF-4730, WF-4734, PX-M780F
WF-7210, WF-7211, WF-7215
WF-7710DWF, WF-7711DWF, WF-7715DWF, WF7720DWF, WF7721DWF, PX-5080F, PX-5081F
WF-C5210, PS-X884
WF-C5290, PX-M884F
WF-5620
WC-C5710, PX-M884F
WF-C5790
WF-C869R, PX-M7070FX
WF-M5799 - Coming Soon - preorder
EP-808
EP-979A3
SC-P400, SC-P407, SC-P408, SC-PX7V2
SC-P600, SC-P607, SC-P608, SC-PX5V2
SC-P800, SC-PX3V
Download chipless Firmware here - http://chiplesssolutions.com/download.shtml
Step 1. Upload chipless firmware to printer. Check current firmware version in Your printer now. If ok - then make Step 2.
Step 2. Run License.exe utility:
- select printer model from drop-down list
-  click on Activate Online button
- input your Activation key
Step 3. Restart the printer.
I purchased an Activation Key for my Epson XP-441. I have been sent, but I do the procedure appears the error (COMMUNICATION FAILED. PLEASE, CHECK CONNECTION BETWEEN PRINTER AND PC.
CHANGE USB PORT. CHECK NETWORK CONNECTION, MAKE SURE THAT PROXY IS NOT USED AND DISABLE FIREWALL.
TRY AGAIN LATER. 10091) Do you know what's going on?
Hello,
I purchased 2 total chipless firmware codes for the Epson SC P800.
I purchased one first and went through the directions. The process was successful and worked properly.
However the second key although seemed to have installed everything without issue does not work. Does this mean that the key is faulty or another issue.
Can someone please get back to me. I want to purchase many more I even inquired about bulk pricing however I cannot move forward with a 50% failure rate please help.
KAIO
Already fixed the problem on server side.
Please reply if you have managed to make chipless
JohnL
Send us the message with your key number and screenshots with problems
By the way we have updated firmware file on April 26 - please use updated firmware (download from site)
I purchased an Activation Key for my Epson XP-241. I follow the procedure but na error appears:(COMMUNICATION FAILED. PLEASE, CHECK CONNECTION BETWEEN PRINTER AND PC.CHANGE USB PORT. CHECK NETWORK CONNECTION, MAKE SURE THAT PROXY IS NOT USED AND DISABLE FIREWALL.
TRY AGAIN LATER. 10091).
I deactivated all firewall. Do you know what's going on?
Hello, I already installed another epson xp 231 and I had no problem, but with the last serial I get that error, I have neither proxy nor firewall. I am using the same PC that I used for the previous printer that installed the chipless without problem.
Hi i have a problem with chipless XP-440. In my opinion internal color profile for glossy papers is not 100% correct. On both original and chipless firmware printer gives strong blue tint if selected profile is glossy. But everything works just fine if matte profile is selected for glossy papers. Sometimes it becomes a problem because often printer and Epson iPrint don`t allow to select matte paper if it's size is 10x15 i.e. standard photo. I have tested XP-342 with the same ink and paper and everything was just fine with both glossy and matte profiles. In my opinion it might be a mistake in original XP-440 FW which was transferred to chipless one. Do you have a chipless FW for XP-440 based on newer original FW which may be free of this problem? Thanks.
Two days ago I started a firmware upgrade (with a 3rd party black ink cartridge installed) on my WF-4734. The upgrade halted in a “Maintenance Error” mode with a message that it “Cannot recognize ink cartridge. Try installing again.” No matter what I do, I can’t get out of that error mode.
After I found your web site, I downloaded your WF4730_FWF475TL_CM13I2.zip file, unzipped it and tried following your directions. I was not able to enter the �special Firmware Update Mode’. Every time my printer powered up, it came up in the “Maintenance Error” mode.
I tried running your EPFWUPD program and it recognized my printer but wouldn’t let me reload the previous firmware version, instead it said my printer's Status was "Downgraded (It cannot be Updated)".
I have since bought and installed a genuine Epson cartridge. I'm out of Maintenance Mode but I still can't get my printer to go into �special Firmware Update Mode’. Does the downgraded status mean my machine can't use your product to go Chipless?
For the Epson wf 2630 chipless --After entering the key and press ok I have "communication failed…. try again later error 10088" what must i do now
Hello. Paid the firmware key for epson xp-440
A letter arrived at the post office
Company: VAL'S FINANCE
Reference Number: D9755272-5B52FE93-463-XXXXX
Subtotal: $ 25.00
Tax: $ 0.00
Shipping: $ 0.00
Total: $ 25.00
VAL'S FINANCE
If This (D9755272-5B52FE93-463-XXXXX) key then it does not work.
11 11
