samuelsamuel
I can't activate - Communication Erro
I have bought order #15763578, but can't activate the key because every time has Communication Eoor 10060
printer is xp442
Please help me to ativate the firmware.
Hi John,
The firmware update went through as expected, but I just ran into that communication error as well (despite of disabling the firewall on my end and testing 2 different USB ports). Just in case it matters, I have a Epson WF PRO 4720 and used the firmware from https://chiplesssolutions.com/download/WF4730_FWF475TL_CM23I5.zip for my update. My order number is #15964616.
Are your servers ok or is there perhaps an alternative approach to activate based on the ID code?
claws_lon, error 10060 means that application could not connect to the server. Server itself is working now so it`s more likely that it`s blocked on your side. Please, install telnet (standard windows utility) and try this command from console (telnet 211.159.168.205:63429) and also read this topic:
https://www.2manuals.com/forum/index.php?/topic/80352-fixing-communication-error-with-the-server/
this one for WIC but the problem is similiar.
this one for WIC but the problem is similar.
Maybe I was too late by just doing my test today, but I had no success using telnet on my machine as well as on my mobile using 2 different ISPs (normal fiber + mobile phone company via 4G). No firewalls were active for the test and I also tried it additionally via a VPN provider to ensure no ISP filtering happens.
C:\>telnet 211.159.168.205 63429
Connecting To 211.159.168.205...Could not open connection to the host, on port 63429: Connect failed
Looking at my TCP viewer I can clearly see that a SYN package was sent, but nothing is coming back (SYN/ACK is missing) as the 2nd step for a TCP handshake. In all cases I simply get a connection timeout, which makes me feel that might be an issue with the remote server not wanting to talk to me rather than a problem on my end.
