Stephanie
Epson SC P-600 Chipless Firmware Didn't Work
I purchased the license and ran through the procedure and it got to the point where it was sending the firmware to my printer and then it turned off. It didn't come back on on its own after 5 minutes, so I turned it on and the ink levels are still reading at various amounts and not the 100%. My license does show as used, but I need to know if it can be reset so I can try again. I'm not sure what I did wrong.
Good day. Unfortunately, this particual  version of the firmware has been blocked for your device either during manufacturing or via recent official firmware update. You need to use firmware from chipless solutions.
If You can't make firmware downgrade by WIC utility - it means Your printer has newest Main board version.
Epson made some changed in new main board.
The solution in this case is here:
Use Activation Keys and License.exe application for P600 -
http://www.2manuals.com/product_info.php?cPath=107&products_id=1850
You can pay now difference in Firmware and Activation Key cost only -
$35 - $20 = $15
Link for payment -
https://store.payproglobal.com/checkout?products[1][id]=47590
Works great now. The only issue I have is that the nozzle check prints very lightly. I would like to correct this if possible.
I have the same problem Stephanie has with the nozzle check not printing anything, other than a few dots here an there. So obviously, everything I print looks like a blank page.
Worked great the first time I installed the firmware. But as soon as I had to replace the empty cartridges, it won't pull out any ink to print. I have a WF-4730
