peterpeter
License.exe does not list my printer.
Good day, each time when you connect usb printer to the PC virtual printing USB port name (USB001,USB002,etc) is assigned, once you install the driver this assignment is remembered and as result the more installed printers you have in the system the higher is port number for the next one. Unfortunately, license.exe can only work with first 32 ports, so in order to use it with the new device, you need to delete one of the existed printers with low port number, freeing it, and then replug the new one (of course it will only work if new device is not installed itself, otherwise it will have fixed port number and nothing will change). Bottom line, remove as much unused printers from the system as possible.
  • Like 1
One customer with the same problem had USB connection desabled on his printer:
Preventing PC Connection via USB
You can disable access from a USB-connected computer. This restricts non-network access to the
product and protects the security of confidential scanned documents.
1. Press the home button, if necessary.
2. Select Settings.
3. Select General Settings.
4. Select Printer Settings.
5. Scroll down and select PC Connection via USB.
6. Select Enable.
what if you can't get to home screen because printer stays in constant error mode due to not recognizing ink cartridges? If the firmware successfully installed, should that message no longer be there?
Printer`s firmware must be updated in the normal mode via USB, if you are disabled USB and unable to reach printer`s settings, you need to temporarily install original cartridges.
Good day. Please, post screenshot with the error here. Also, make sure that you installed correct version of the firmware in the normal mode, chipless firmware can not be installed in the service mode at the present moment, and try to change USB cable and port.
