BrwaQ 0 Report post Posted February 1, 2020 Hello this is my printer C5710 and does not work with the license.exe, it says activation code writing is failed thanks Share this post Link to post Share on other sites
John_Admin 388 Report post Posted February 1, 2020 Are you sure you enter right Activation Key? Share this post Link to post Share on other sites
BrwaQ 0 Report post Posted February 2, 2020 yes dear it worked previously, but suddenly i've updated to epson's new update i tried to make it chipless again and this error comes out e2BMPfrlI7n7V9SNpme5fjau8hgAAAAAawAAALqmJL/IKtbQLPzyS1wjsBNixsbWAgAAADoA AACtAAAApwAAACC6GBBAAGy******P8zANckAMsalQAFCAAKAO8x*****gIAAFkpzKDQ9WsN zaGsBQAAAAAAAAAAfFcwA2AAAAA= is it right ? Share this post Link to post Share on other sites
John_Admin 388 Report post Posted February 2, 2020 Please download firmware here - https://chiplesssolutions.com/download/WFC5710_FWG239TL_ZZ99Z9.zip Upload firmware to printer in normal mode - dont put printer in Program Update mode. The uploading process will stuck at 70-80% - it is ok! Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer and run License utility and use your Activation Key you have used first time. Please reply about results. Share this post Link to post Share on other sites
BrwaQ 0 Report post Posted February 2, 2020 My friend the printer restarts at 71% and then the rest of the update from 71% to 100% is continuing and after that it says update is failed Share this post Link to post Share on other sites
John_Admin 388 Report post Posted February 3, 2020 Ok Now use License and Activation Key Share this post Link to post Share on other sites
