Giagkou
Unable to make Epson wf-c5710 chipless working
I purchased a key today, and tried following the steps:
I've tried flashing the WFC5710_FWG239TL_ZZ99Z9.zip firmware using the original instructions (power off, 4+7+Job/Status), as well as the revised instructions to run it under normal mode.
Results:   Firmware update mode:   Enters mode just fine, displays white text. Says "PRINTER UPDATE MODE", then "CU06" in middle of screen. Upload proceeds, then finishes with "FINISHED, ROM VERSION 16.54.CU26I9, ROM1 FIXSUM D528 , ROM2 FIXSUM 6C60".   After this, all lights flash at about 1 second intervals, but unlike guide, pressing the center of the LCD (or anywhere else or any other button) doesn't reboot the printer.  I have to pull the plug at this point or pressing the 0 button .
Running NoInks updater at this point fails with a message like this "[] ".
Trying again with the printer in normal mode, firmware uploads, printer reboots by approx 30-40% on the progress bar. If I let the normal mode firmware updater run all the way to 100%, it finally fails with a message about "firmware not installed" (your printer isn't content check USB cable, WiFi or something like that.)
Any ideas to solve my problem ?
Any help would be appreciated.
Firmware update mode:   Enters mode just fine, displays white text. Says "PRINTER UPDATE MODE", then "CU06" in middle of screen. Upload proceeds, then finishes with "FINISHED, ROM VERSION 16.54.CU26I9, ROM1 FIXSUM D528, ROM2 FIXSUM 6C60".   After this, all lights flash at about 1 second intervals, but unlike guide, pressing the center of the LCD (or anywhere else or any other button) doesn't reboot the printer.  I have to pull the plug at this point or pressing the 0 button .
