Wmaster1o
2 WORKFORCE WF-7720 NAO ATUALIZAN -- changed printer cards
tengo 2 impresoras WF-7720 no se pueden activar las dos marcan error de comunicacion - 10091
deshabilite el firewall de windows
deshabilite el antivirus
deshabilite el windwos defender
deshabilite todas las impresoras conectadas por usb
Y NO FUNCIONA LA ACTIVACION
Good day. 10091 means that application could not connect to the server. Please, check if you have the access:
1. Enable telnet client in the windows components.
2. In the command line type telnet 211.159.168.205 20102
If you get empty screen with input prompt it means that server is available system wide and something is blocking license.exe specifically.
If you get any error this means that either this IP/port blocked locally for the entire system or on the router/provider side or server is currently not available.
I also checked it right now and server is working.
I ended up changing the 2 cards, I never managed to activate them.
The new ones activated instantly.
If you need any reference about the cards you remove and could not be activated to improve the service. I am glad to support.
1. Telnet is standard windows application that in no way connected to the chipless firmwares.
2. Send me an order number and two problematic keys in the private message.
