Sublime_Vizion 0 Report post Posted June 22, 2020 Hi. I'm getting error 031002. The printer stops and I have to power off. It happens every time I try to print. Both the firmware downgrade and Chipless activation is done. Help please! Share this post Link to post Share on other sites
wic.support 21 Report post Posted June 22, 2020 Good day. This error (0x791A) means: X-Hot detection error during flushing. Head thermistor detects abnormal temperature. Possible causes: Printer head failure. Main board failure. Share this post Link to post Share on other sites
Sublime_Vizion 0 Report post Posted June 23, 2020 Thank you for the reply. It gives me this error when I activate the chipless software. If I just downgrade the firmware but do NOT activate the chipless software the printer works fine. Why does the activation do this? I paid for the key since I was able to downgrade but it's useless if the chipless activation does this to the printer. Share this post Link to post Share on other sites
TordenGud 1 Report post Posted September 11, 2020 I have the same problem, printer error 031002. For Epson XP-15000. Windows 10. My printer is fresh, new from the box, with no modifications when this occurs. I think I have found the pattern as to when 031002 occurs. The error appears every time any Maintenance function is activated from the printer's little screen navigation. (I don't know about from Windows 10 Epson window navigation, I have not tried.) Even changing the ink cartridges will cause 031002. It appears with original Epson cartridges AND with FullColor CISS cartridges. Official Epson cartridges or 3rd party cartridges all create this error. I can delete the error by a long process of reinstalling the original Epson Firmware again. Then restarting the printer. Then reinstalling the Chipless EPFWUPD.exe again, following the instructions precisely. Then whichever ink cartridges are currently in the printer must stay in the printer. Any attempt to touch the Maintenance functions on the little screen to change the cartridges, or check ink levels, or check alignment, or check the printheads, or clean the printheads, will bring 031002 again. Then the painful process of starting over by reinstalling the original Epson Firmware must begin again. I did not see an option to buy a forever Activation Code, which I had intended to buy. Now that I know I need it to keep this current version of the Chipless EPFWUPD.exe functioning, is it possible to purchase "forever" for the extra $5 or $3 or whatever the difference is? I would also happily repurchase everything again if necessary if there is an update/fix/patch for this Error Code 031002. Thank you! Share this post Link to post Share on other sites
John_Admin 373 Report post Posted September 11, 2020 is it possible to purchase "forever" the key you purchased already IS "forever" for your printer Share this post Link to post Share on other sites
wic.support 21 Report post Posted September 21, 2020 Chipless firmware for XP-1500 has been updated, reupload firmware and reactivate it with the same key, then tell the results.New firmware can be downloaded from here:https://chiplesssolutions.com/download/chipless/XP15000_FWG150TL_NW07K7_NW99Z9.zip Share this post Link to post Share on other sites
TordenGud 1 Report post Posted September 21, 2020 Thank you, wic.support! I will do it as soon as I can, and reply again! Share this post Link to post Share on other sites
TordenGud 1 Report post Posted September 22, 2020 Hello, I'm back! Everything works flawlessly! I obviously don't know how you made it operate so smooth and perfectly now, but its performance is invincible. I pressed all the buttons, even pretended to change ink cartridges (just taking my CISS in and out), and it still kept going perfectly! Thank you very, very much! 1 Share this post Link to post Share on other sites
mrbluesky 0 Report post Posted September 22, 2020 Hi I am having the same issue with my printer. can anyone please tell me where i can find the original Epson firmware to reset the error code? i have tried the newest update 3 times and it is still failing. i just purchased a "forever" activation code and it is not working. Any help will be greatly appreciated. Share this post Link to post Share on other sites
TordenGud 1 Report post Posted September 22, 2020 I had found the original Epson Firmware here: https://epson.com/Support/Printers/Single-Function-Inkjet-Printers/XP-Series/Epson-XP-15000/s/SPT_C11CG43201 Share this post Link to post Share on other sites
John_Admin 373 Report post Posted September 23, 2020 i have tried the newest update 3 times and it is still failing. please give us screenshots of what happens? Also be sure you have downloaded updated firmware for 15000 - https://chiplesssolutions.com/download/chipless/XP15000_FWG150TL_NW07K7_NW99Z9.zip And it has to be flashed to printer in NORMAL MODE Follow Step by Step Tutorial to make your printer chipless - http://www.2manuals.com/product_info.php?cPath=107&products_id=1857 Share this post Link to post Share on other sites
TordenGud 1 Report post Posted October 4, 2020 Rats... I hate to report a new different problem.... Everything has been fine for these couple weeks. Mysteriously, a new problem popped up upon turning on the printer again today. The little XP-15000 screen says: "Printer Error | Turn on the printer again. See your documentation for more details. 033007" Obviously, I turned off the printer, and then back on again. Same 033007 error. I also turned off the printer. Unplugged it for a few seconds. Then plugged it back and powered it back up. Same 033007 complaint. I also reinstalled this new firmware. Installation goes smoothly. Upon finishing the final step of turning off the printer (without unplugging it) and turning it back on, it's the same 033007. Re-help again, please? Thank you! Share this post Link to post Share on other sites
scuzzi 0 Report post Posted October 28, 2020 I ran the firmware update and the printer restarted as indicated in the updater (somewhere around 70% complete) however once restarted it went into the "change ink cartridge" screen, however I let the process continue. It got to 99% then stopped saying the update had failed, however when I checked the printer reported it was now running firmware version NW20I7 (as it should). So I applied the chip free license and after reboot it indicated all my tanks were now full, again as it should, so I went ahead and replaced my cyan, magenta & yellow OEM cartridges that are now empty with the 3rd party "compatible" ones it wouldn't recognize. After changing them it requested I perform a nozzle check which I did ...... and the page came out blank. I then tried printing an image ........ blank page. I tried a nozzle clean and the printer stopped mid process throwing up a '31002' error. I restarted and it now showed a "31005" error. I went through the firmware upload again along with the chip free license recovery and while it's not giving any errors now it's still printing "invisible" output! Share this post Link to post Share on other sites
