boxx17 0 Report post Posted February 22, 2020 I am having some trouble finding the instructions for installing the chipless firmware for Epson XP-15000, so I am guessing at the process from just a few comments I have read. I was able to run the firmware installer (XP15000_FWG150TL_NW20I7_NW99Z9) and upload it to the printer in program update mode (via USB), that seems to work ok. It says "finished". The buttons don't work so I can only unplug it to turn it off. How do I know if it worked? When I go into settings on the printer and view the firmware version, I just see NW2017. It still barks at me about ink levels (I suppose it would until I purchased the license). When I run the firmware installer in normal mode, the screen indicates its updating firmware for a minute or two and then, just goes to the normal epson menu (maintenance, settings, wifi) but the power light flashes steadily (but maybe because one ink cart is out?) The app on the PC will continue to slowly progress all the way to 100% where then I finally get the message "The printer's firmware was not updated." Did it update the first time around and I am just not aware? I didn't want to buy the license until I had some sort of confirmation its installed and will work correctly. Without instructions, I am not clear if I already updated it in 'program update mode' following the small instruction set where you download the firmware prior to buying the license or if thats just testing - or if I am supposed to do that in normal mode? - Some other models look like I am supposed to do it in normal mode, but thats the bit thats not working. Any help would be appreciated. Thank you! Share this post Link to post Share on other sites
wic.support 31 Report post Posted February 22, 2020 NW20I7 is not correct version so upload NW07K7 version if you see some data readed in the top input field then firmware is succesfully loaded. Share this post Link to post Share on other sites
pc_system.bo@hotmail.com 0 Report post Posted July 27, 2020 I am trying to load the firmware on an Epson XP15000 printer, but it only reaches 99%, I tried several times, but I get the same error A little help Share this post Link to post Share on other sites
John_Admin 393 Report post Posted July 27, 2020 What is current firmware version in your printer now? Share this post Link to post Share on other sites
pc_system.bo@hotmail.com 0 Report post Posted July 27, 2020 NW20l7 Share this post Link to post Share on other sites
wic.support 31 Report post Posted July 27, 2020 This is wrong version Download correct version NW07K7 - https://chiplesssolutions.com/download/chipless/XP15000_FWG150TL_NW07K7_NW99Z9.zip Share this post Link to post Share on other sites
Dinero 0 Report post Posted January 20, 2024 Would you need to be buy the chipless software if you update to NW07K7 from NW2017 or could you just use the recovery key that you get after installing the firmware? And if you can use the recovery key, how would you go about using it? By the way i have the chipless software from inkchip. Im asking because im having a print error 031001 and 031002 on my epson xp15000 and im wondering if this could be the problem because i read something about this on another forum. Share this post Link to post Share on other sites
