lic.gaveglio@gmail.com 0 Report post Posted September 26, 2023 Hello, I am getting communication error 2100012C. I have uninstalled the printer, I have reset the continuous system reel, it is changed from USB, I have set the adjust program compatibility in win xp service pack 3 and the error continues... I have win 10 pro can you give me an idea where to go next! epson 1430 Share this post Link to post Share on other sites
wic.support 31 Report post Posted September 27, 2023 Good day. What model exactly do you have? Epson Stylus Photo 1430? What application you are using (please, post a screenshot)? Try to select printer's USB port manually in the ajp settings dialog and post the results. Also, try to read printer's data from the WIC and write what will happen. Share this post Link to post Share on other sites
lic.gaveglio@gmail.com 0 Report post Posted September 27, 2023 (edited) hola el modelo es epson 1430w formato a3 ya pude reestablecer el reseteo de las almohadillas, y yo tenia un sistema continuo viejo el que usaba hasta hace unos días y compre uno nuevo por lo que pienso que es el chip; al hacer todas las pruebas y no lograrlo, probe cambiar la plaqueta del chip del sistema continuo y lo hice! y aun asi no hay modificacion alguna! lo que si observe en un momento dado del sistema continuo viejo poruqe uno de los cartuchos estaba pinchado y derramaba tinta, es que salio un humo blanco de abajo del carretel; y un poco de olor a quemado!, supongo y quiero esperar que sea una cuestion de calentamiento en una zona que no afecte a ningun circuito; alguien podria adviinar de que se trata? Edited September 27, 2023 by lic.gaveglio@gmail.com Detalle a tener en cuenta Share this post Link to post Share on other sites
John_Admin 390 Report post Posted September 27, 2023 Please contact the person you have get this program directly. Software we offer - doesn't have such problems Share this post Link to post Share on other sites
