tdudash 0 Report post Posted October 5 My WF-C5710 is currently running Firmware version CU2619. I have found documented chipless support for CU24JA and CU24M3, and I see that CU26OC is now supported by at least one chipless provider. Does Chipless Solutions have an archived CU24JA or CU24M3 Epson firmware that you have personally verified can be loaded onto a CU2619 machine? If so, what is the exact firmware version and recovery procedure? Share this post Link to post Share on other sites
wic.support 31 Report post Posted October 25 Good day. Unfortunately, there are just too many different firmware versions to test every permutation. I’m pretty sure that CU26I9 should allow you to use either CU24JA or CU24M3, but I cannot guarantee it 100%. That said, you do not need to buy the activation key until the chipless firmware has been successfully uploaded to the printer. First download the firmware: Older version: https://www.chiplesssolutions.com/download/chipless/WFC5710_FWG239TL_CU24JA_CU99Z9.zip Newer version: https://www.chiplesssolutions.com/download/chipless/WFC5710_FWG239TL_CU24M3_CU99Z9.zip Then upload it to the printer following instructions below and make sure that license software can read printer's ID. Once this is done you can buy the key and activate the printer. https://forum.2manuals.com/index.php?/topic/80765-how-to-update-and-activate-chipless-firmware-complete-guide/ Share this post Link to post Share on other sites
