HartoPrinters 0 Report post Posted September 20, 2014 I was almost runnnin out of ink, I refill it manually, dont wait to show warning, now the ink led its permanenly on, and dont let me print anything. I download the Adjustament Program and reset the ink pad waste counter succesfully, try to make a charge of ink and Ink Out Error keeps appearing. Status info is that de 4 botles are empty, although they have ink. When the Status Manager shows the error window, does not appear the images with the levels of ink, and does not give me the option to enter the ink serial numbers. Can anyone help me ? Share this post Link to post Share on other sites
John_Admin 388 Report post Posted September 21, 2014 Yes I can help you. But you could also help youself if you had a try to make a search. Ok - reset inks in L110 like here - http://2manuals.com/forum/index.php?/topic/80122-how-to-reset-ink-levels-in-epson-l110-l210-l550/page__pid__84990#entry84990 Share this post Link to post Share on other sites
Fretz 0 Report post Posted July 20, 2015 (edited) Is this an ink tank system? It seems like the ink tubes were blocked or clogged. Also, check the choke valve if it is pointed at the printer. Try moving the valve, back and forth to loosen the ink tube. Edited July 20, 2015 by Fretz Share this post Link to post Share on other sites
