JesseVoss 0 Report post Posted May 18, 2018 My Epson Xp760 Screen has advised me that my ink ad has come to the end of it's service life. I believe there is a lot more life in the pad. How do I: 1. Reset the pad pezo settings 2. Clen the pad to extend it's life further? Hope you can help, I'm stuck. The printer is only 16 months old and has not been used every day. I don't believe the pad could possibly be full? Share this post Link to post Share on other sites
John_Admin 390 Report post Posted May 18, 2018 Use WIC Reset utility to reset waste ink counter Share this post Link to post Share on other sites
Hoffy 0 Report post Posted June 3, 2018 It is very possible if you print a lot and if you reset without emptying the waste tank you will have ink everywhere. A trick is to leave on the printer as every time it starts it does a head clean and that soaks ink through to the waste tank via the print heads so you tube how to clean or change the waste ink pad you can use sanitary napkins as a absorbent medium and buy your reset key and away you go again Share this post Link to post Share on other sites
