Epsy 0 Report post Posted September 27, 2018 I just got a used WF-5620 and it only has one set of 3rd Party Cartridges, partly filled. I want to make it chipless. After reading so much about other printers demanding original Epson Catridges after a firmware change I am unsure whether it will go well if I do a Chipless update. Will it work also without original Cartridges? Share this post Link to post Share on other sites
John_Admin 390 Report post Posted September 28, 2018 Yes You can change printers firmware to verson with disabed ink cartridges. For 5620 model it can be done in service mode - no need ink cartridges installed - http://prntscr.com/kzpepr Share this post Link to post Share on other sites
Epsy 0 Report post Posted October 1, 2018 Thank you, John, for your answer. So, I understand correctly, that it will not matter whether there is a cartridge in it nor will it matter whether it is original Epson or third party cartdrige? I do NOT have original Epson cartridges to insert if the process notifies about trouble. One more "little" problem: This printer does not accept thick paper (160 g/m2) in the paper cassette. It will eject the paper and say "paper jam". (How does it find out about paper weight? can I disable that?) An alternative would be to use the rear tray, but here it will not do duplex printing (Obviously, thick photo paper does only have ONE shiny side, and the back side should not be printed on. I understand). But I want to print little broshures in duplex mode, on 160 g paper. My older printer WF7525 does exactly this without any problem, although it does it slowly and it may overheat. The WF5620 does already have firmware GM09GC installed. But the Version GM09GC that you deliver is a modified one, correct? Somewhere I was reading that Epson uses Linux software open source. Consequently I assume there should be a way to access the necessary settings (paper weigth, duplex printing) and change them. Can you please give me hints on how to do that? You may as well contact me by email or PM. Thanks again. Share this post Link to post Share on other sites
