Blackhawk 0 Report post Posted March 6, 2020 In my confirmation email I did not get an activation key, the field is just blank. Share this post Link to post Share on other sites
Blackhawk 0 Report post Posted March 7, 2020 Further to this I don't think I've had much luck with changing the firmware. If I download the firmware from here: https://www.2manuals.com/product_info.php?cPath=107&products_id=1851 And try to install with the printer turned on and in a normal state then it takes a long time to update, gets to 99% and then fails. If I check with wicreset the firmware version has not changed. If I try to install with the printer in the 'firmware update' mode (by holding down the four buttons) then the firmware update happens much faster, says that it completed and the power light on the printer starts flashing. If I turn the printer off at that point and turn it back on again it starts OK but when I check the firmware version with wicreset the version has not changed. Any tips? Even when I eventually do get my license key at this point I'm not sure if it will even work if the firmware version on the printer never seems to change (currently FA20I4 20/04/2018) Share this post Link to post Share on other sites
John_Admin 373 Report post Posted March 7, 2020 What is your current firmware version now? Share this post Link to post Share on other sites
Blackhawk 0 Report post Posted March 7, 2020 As I said in the message above, the current firmware is FA20I4 20/04/2018 and nothing I've done so far has changed that. Also as I said before I've paid but did not receive a license key in the email I got, the space was blank. Share this post Link to post Share on other sites
Blackhawk 0 Report post Posted March 8, 2020 Can I please just get my activation code? I could probably have figured out the firmware myself by now if you'd sent me the code when you replied to this thread before, I hope I don't have to wait another 24 hours for somebody to check the forum. Share this post Link to post Share on other sites
John_Admin 373 Report post Posted March 8, 2020 FA20I4 is right version So you have already uploaded to printer Now you have to run License utility and use your Activation Key. You can find all your orders and keys in your 2manuals account Share this post Link to post Share on other sites
Blackhawk 0 Report post Posted March 8, 2020 That worked perfectly, now at 100% on all inks, thanks! Share this post Link to post Share on other sites
