jfprinter 0 Report post Posted May 13, 2020 Hello Team Chipless, I activated the C5290 (already activated 3 of thesee before with your keys), and the Recovery File wasn't generated afther the process was completed. Like the other activations I made. Please, tell me how to adquire the recovery file just in case something happens to the printer firmware. Also, I would like to point out that the activator works with errors, If I don't open the program quickly, select the printer quickly, and then activate quiclky, It will not work, and I think that might have been a reason why the activator didn't generated a recovery file for that activation in particular. Also, activated C5290 printers sometimes, when already succesfully activated, ask for original ink bags, you turn it off, and on again, and it's ok, but just a commentary, so you can improve this wonderful solution. Greetings, Juan Share this post Link to post Share on other sites
John_Admin 389 Report post Posted May 14, 2020 If printer will update - Just repeat all procedure with updater and key Share this post Link to post Share on other sites
