hovuongchau 0 Report post Posted June 16, 2020 Previously I used 3 epson wf-7110 with chipless key. At first the machine ran very well. But after a period of use, the error "close ink cartridge cover". Accompanied by error 0x69, the printer cannot work. I switched to using 2 epson wf-7710 with chipless key. At first the machine ran very well. But after a period of use, the error "close ink cartridge cover". Accompanied by the error "034503", the printer cannot work. I don't know what to do, so I should ask the Admin for help. And I am very grateful. Share this post Link to post Share on other sites
wic.support 21 Report post Posted June 16, 2020 Both 0x69 and 34503 means: ink system clutch operation contact point detection error. i.e. printer unable to detect that cartrige cover is closed, we never had complaints like this before, let alone from the two unrelated models. I think the problem is with the setup of the CISS system or cartridges. Try to remove everything from the printhead, close the cover and check if you still see this error when it is empty. Share this post Link to post Share on other sites
mediaonebataan 0 Report post Posted February 23 Sir have you resolve the issue? Share this post Link to post Share on other sites
