rnimportgye@outlook.com 0 Report post Posted July 14, 2020 alguna ayuda no me carag el firware versión LF26I1 ya he cambiado de cable usb y de pc y llega hasta 14 % Share this post Link to post Share on other sites
John_Admin 393 Report post Posted July 15, 2020 Delete all other printers from your PC Reboot PC Connect printer byu USB cable Download and extract files from archive - https://chiplesssolutions.com/download/chipless/WF2630_FWE728TL_LF26I1_LF99Z9.zip Upload firmware to printer in NORMAL MODE I mean dont put printer in Firmware mode Waite until printer restarts Then shut down updater and run License.exe application and use your key Share this post Link to post Share on other sites
BETICO2010 0 Report post Posted September 5, 2020 no me carga el firmware WF2630_FWE728TL_LF26I1_LF99Z9 en wf2630 se ve la misma version con la que llego ya utilice la clave pero sigue apareciendo cartuchos bajos I do not load the firmware WF2630_FWE728TL LF26I1_LF 99Z9 in wf 2630 it looks the same version with which I arrived I already used the password but still low cartridges appear Share this post Link to post Share on other sites
John_Admin 393 Report post Posted September 6, 2020 Download and extract files from archive - https://chiplesssolutions.com/download/chipless/WF2630_FWE728TL_LF26I1_LF99Z9.zip Upload firmware to printer in NORMAL MODE Share this post Link to post Share on other sites
morris 0 Report post Posted September 17, 2021 @john. The firmware does not finish updating. Am stuck Share this post Link to post Share on other sites
John_Admin 393 Report post Posted September 18, 2021 When Firmware Update process is complete - printer will restart - usually it will take only a few minutes but can continue for 10-20 minutes in some rare cases. If process hangs or stops at 80-99% - replug power cable and start printer manually.Now check current firmware version ( how to check). If firmware version is LF26I1 - firmware has been uploaded successfully. You can go to next Step. If NO - restart the printer and try once more time. Share this post Link to post Share on other sites
morris 0 Report post Posted September 19, 2021 I successfully did it using a different method, i think i was not patnt to wait printer to restat. I was pressing the ok button to force restart. Thanks alot @john. Share this post Link to post Share on other sites
