guigs199 0 Report post Posted October 29, 2020 Hi, i'm having this error on my xp 241, anyone knows what i need to do to fix it? Thanks Model Name XP-240 Series Status Fatal error Firmware ver. MF07I3 07/03/2018 Serial Number X2CW021852 Print Head ID 3988E68N0M Manual cleaning counter 16 Timer cleaning counter 1 Ink replacement cleaning counter 0 Total print pass counter 2112 Total print page counter 39 Total scan counter 11 First TI received time 18/03/2018 Last printer fatal error code 1 0x80E9 Blowout of a fuse (CRCM). Last printer fatal error code 2 0x80E9 Blowout of a fuse (CRCM). Last printer fatal error code 3 0x80E9 Blowout of a fuse (CRCM). Last printer fatal error code 4 0x80E9 Blowout of a fuse (CRCM). Last printer fatal error code 5 0x80E9 Blowout of a fuse (CRCM). Last scanner fatal error code 1 0x10 Scanner/ADF home position detection error. CIS Module failure. Scanner housing upper failure (home seek pattern is dirty). Scanner housing lower failure (the rack section is damaged). Scanner motor failure. Insufficient grease. Foreign object. Cable or FFC disconnection. Main board failure. Last general fatal error code 1 0x00 Fatal error does not occur. Last general fatal error code 2 0x00 Fatal error does not occur. Last general fatal error code 3 0x00 Fatal error does not occur. Last general fatal error code 4 0x00 Fatal error does not occur. Last general fatal error code 5 0x00 Fatal error does not occur. Obs: this happened becouse i disconnected the flat cable that goes in the back of the cart, and had a hard time to put it back. Anyone knows what that flat cable do? Share this post Link to post Share on other sites
John_Admin 373 Report post Posted October 30, 2020 You have to connect all cables back Share this post Link to post Share on other sites
guigs199 0 Report post Posted November 5, 2020 I have disconnect and connect those cables (scanner ones), every time that i open the printer to check if its all ok. But it still dont work. I dont know what that cable that go on the back of the cart do, but i think that cable broke while i was trying to put it on, thats why i want to know what that cable do. Share this post Link to post Share on other sites
John_Admin 373 Report post Posted November 6, 2020 Replace that cable by new one Share this post Link to post Share on other sites
