bsnmcahi 0 Report post Posted September 3, 2019 I have the P600, I changed the firmware to chipless using the key and WIC tool from here. I have installed 2 new ink cartridges compatible versions so far and they worked. I am installing the Vivid Magenta and i cant get it to recognise it. The two screenshots of the WIC report show the difference when i have genuine cartridge and compatible ones installed. I have turned the printer off and on again still same error. Can anybody help to force this to clear and force it to reset the VM Share this post Link to post Share on other sites
wic.support 21 Report post Posted September 3, 2019 Open and close ink cartridges case Share this post Link to post Share on other sites
bsnmcahi 0 Report post Posted September 3, 2019 Hi, when i did the firmware update it all seemed to run straight forward and give the success message and no errors. But the firmware shown is not AT12GC, but i defo thought i followed the instructions. Share this post Link to post Share on other sites
bsnmcahi 0 Report post Posted September 3, 2019 So I need to re-run the firmware update again? What happened when i run the process did i select the wrong firmware at somepoint i don't remember doing that. Or is the firmware choice determined by the given key? Share this post Link to post Share on other sites
bsnmcahi 0 Report post Posted September 3, 2019 my key order number was: 17612069 Share this post Link to post Share on other sites
bsnmcahi 0 Report post Posted September 3, 2019 its very strange. I check the key status and it says this: Key: 37A3EEZ442727866 (firmware update/downgrade only). Created: 2019-01-24 10:29:23 (UTC+2). Status: You cannot use this key anymore because it has been already used on 2019-08-31 21:07:15 (UTC+2). You need a new key. This key has been used for printer firmware upgrade/downgrade to 'SCP600.NOINKS' version. Your current IP address - 86.7.98.71 (GB). So the firmware given was SCP600.NOINKS. but the firmware has not updated on my report tool in WIC. Share this post Link to post Share on other sites
wic.support 21 Report post Posted September 3, 2019 Good day. It may be possible that printer updated firmware again automatically if it was connected to the network, please, check private messages. Share this post Link to post Share on other sites
bsnmcahi 0 Report post Posted September 3, 2019 where is the link for the firmware app you was talking about?. looking for the archive but can't see it. found this? https://www.2manuals.com/product_info.php?cPath=56_57&products_id=1696 Share this post Link to post Share on other sites
bsnmcahi 0 Report post Posted September 3, 2019 think i have got it: http://chiplesssolutions.com/download/P600_FWE282TL_AT13H6.zip Share this post Link to post Share on other sites
