jaxson311 0 Report post Posted July 5, 2020 Hi, I am trying to make my epson wf 7710 chipless, I installed the update necessary (so the usb connection isn't faulty) yet when I run the license.exe, everything is blank and I can't select my printer to input my key. Usb connection is not disabled on my printer (saw that as a suggested solution on another forum post). Share this post Link to post Share on other sites
John_Admin 393 Report post Posted July 5, 2020 Try following: - replace USB cable - change USB port - delete all other printer installed on PC - reboot PC restart printer - try on other PC Share this post Link to post Share on other sites
jaxson311 0 Report post Posted July 9, 2020 I have changed the cable and tried another computer, the printer still isn't being recognised. The printer shows version FA24I5, and I have uninstalled other printers (although this is for home and so I do not have many other printers connected). I have rebooted the printer and computers multiple times Share this post Link to post Share on other sites
John_Admin 393 Report post Posted July 9, 2020 If you tried other computers and other USB cables - maybe something with printers USB port. Firmware Updater and License.exe use different protocols. So try to use new USB cable Something on your side Share this post Link to post Share on other sites
jaxson311 0 Report post Posted July 10, 2020 Hi, I figured it out- I was using the front usb port that I assume is only intended for storing scans and such, I was unaware that there was another on the side, which was able to allow the printer to communicate with my computer. I assumed that the connection worked due to the firmware update going through but after checking I saw that this update was done over my network and not through the cable. Thank you for the help Share this post Link to post Share on other sites
John_Admin 393 Report post Posted July 10, 2020 thank you for reply Share this post Link to post Share on other sites
ForceBadger 0 Report post Posted July 30, 2021 The printer shows version FA24I5, and I have uninstalled other printers (although this is for home and so I do not have many other printers connected). I have rebooted the printer and computers multiple times UPSers Share this post Link to post Share on other sites
John_Admin 393 Report post Posted July 30, 2021 good Share this post Link to post Share on other sites
