dany0808 0 Report post Posted September 16, 2021 Hello, I successfully loaded this chiples firmware (in normal mode), then I successfully activated it with purchased key. The issue is that after power off and then power on printer (without disconnecting) printer still shows not ink detected, chipless is not working despite firmware is loaded and activated. I need help please Share this post Link to post Share on other sites
John_Admin 393 Report post Posted September 18, 2021 What is your current firmware version now in your printer??? How to check - https://www.wic.support/how-to-check-current-printer-firmware-version-and-available-firmware-version-for-downgrading-in-wic/ Give us Your Order Number also Share this post Link to post Share on other sites
dany0808 0 Report post Posted September 18, 2021 @John_Admin thank you for your answer I hope you can Help me, Wic reset do not work with this C869R, firmware version: Printer: I do not know order number, but this is key that was successfully activated: BD62Q-9KMQX-R494P-TD9X8-3TVQT Share this post Link to post Share on other sites
dany0808 0 Report post Posted September 18, 2021 Right now (after doing procedure I told you before) this appears when enter to firmware mode: Note: I also tried to upload chipless firmware in this mode, transfer 100 successfull, but still after activating with license it shows not recognize ink Share this post Link to post Share on other sites
John_Admin 393 Report post Posted September 19, 2021 First we need o find your Order. Please tell us Your Order Number. We cant find orders placed with your email. Share this post Link to post Share on other sites
dany0808 0 Report post Posted October 2, 2021 I already told you this is my key BD62Q-9KMQX-R494P-TD9X8-3TVQT , I purchased it from a reseller, hope that's not a problem, I suppose you can verify the key is valid. If I have to purchase another key tell me, but I want to know if it will work. (Firmware loaded and activated to my printer is the one from https://chiplesssolutions.com/download.shtml) Share this post Link to post Share on other sites
John_Admin 393 Report post Posted October 3, 2021 This Key has been used on September 10 IP address: 152.231.200.247 Port: 50012 Share this post Link to post Share on other sites
dany0808 0 Report post Posted October 3, 2021 Yes it was succesfully activated but chipless is not working, printer still shows no ink and can not print or copy. Share this post Link to post Share on other sites
John_Admin 393 Report post Posted October 4, 2021 Upload chipless firmware to printer once more time. Make it in normal mode. Dont put printer in firmware mode. Then use Recovery Code Not Activation Key Share this post Link to post Share on other sites
dany0808 0 Report post Posted October 4, 2021 Yes I have tried exactly that in that order many times, I have done it with many other printers. The issue should be somewhere else, don't you have any updated firmware for this model? Share this post Link to post Share on other sites
John_Admin 393 Report post Posted October 5, 2021 Give us screenshots what happen after You input Recovery Code Share this post Link to post Share on other sites
dany0808 0 Report post Posted November 4, 2021 For these days I do not have the printer with me, but I still need to solve the problem as soon as possible. After inpunt recovery code it writes ok but every time after power off then power on printer, it always shows no ink status. Could you please confirm if devolopers are working on a updated chipless firmware for WF-C869R ? Share this post Link to post Share on other sites
