Gary 0 Report post Posted September 17, 2021 RE:EPSON XP 15000 I am a newbee to thiS site and this is my 1st experience with chipless. If the new chipless firm wear is showing properly imbedded into printer, and I was able to see the printer turnoff and restart and ultimately the 'installation soft wear" stopped loading at 99%, and then two warnings came up at 99% indicating that the firm wear was NOT INSTALLED,. Can I buy the license?? best regrds to all Share this post Link to post Share on other sites
John_Admin 393 Report post Posted September 18, 2021 When Firmware Update process is complete - printer will restart - usually it will take only a few minutes but can continue for 10-20 minutes in some rare cases. If process hangs or stops at 80-99% - replug power cable and start printer manually.Now check current firmware version ( how to check ). If firmware version is NW07K7 - firmware has been uploaded successfully. You can go to next Step. If NO - restart the printer and try once more time. Share this post Link to post Share on other sites
dnp 0 Report post Posted October 16, 2021 Hi all, EPSON XP 15000 I am a newbee to thiS site and this is my 1st experience with chipless.install and as per instruction update firmware version show NW07k7and after that activate. all those process after i face white ink problem. whatever i can print white its not print. i used acro rip10.3 for white ink. i also try print test print but except white ink all color print working fine. anyone suggest whats real problem. Share this post Link to post Share on other sites
John_Admin 393 Report post Posted October 16, 2021 You have to use regular Epson XP15000 printer drivers We dont support acrorip Share this post Link to post Share on other sites
