toppc12 2 Report post Posted April 28, 2022 Hello. I have 2 WF-579R with chipless firmware, both with the same problem. Neither has yellow color working. Instead of yellow, printer prints black, sometimes cyan. And the pattern is blurry. I've done tens of cleanings but nothing will make it work. If I swap ink cartridges, for example, put yellow on cyan, after a couple o cleanings, cyan prints yellow, so ink cartridge is fine and ink is fine. Even yellow starts printing blurry yellow with yellow ink in cyan. One printer got to about 20k copies and the other about 3k before yellow started to print blurry. So I was wondering if it's not a firmware problem. Do you have a chipless firmware older than CE16L7 for me to try? Thank you! Share this post Link to post Share on other sites
John_Admin 393 Report post Posted April 29, 2022 You had working printer with the same firmware version when it started to print bad quality. So it is hardware problem Not Firmware Firmware version has not been changed I offer you to contact printer developer - Epson - to solve the problem Share this post Link to post Share on other sites
Nabil 0 Report post Posted September 10, 2023 Hellow Team how are you i have more than 100PCS of 579R for trading after installed the chipless firmware and key, There is some problem and WIFI not working and Lan (net work connection) that means not recognize LAN Please let me know very urgent if you already solved this problem and if update firmware Share this post Link to post Share on other sites
John_Admin 393 Report post Posted September 11, 2023 Current available firmware version is - CE16L7 Share this post Link to post Share on other sites
