Ted 0 Report post Posted March 21 I am using auto reset cartridges in my R3000. All but one cartridge reads as very low on ink, almost empty. I changed a damper in the R3000 and now need to use the adjustment program to get ink in those two channels back to the printhead. However, the adjustment program will not proceed with the ink charge because the printer is telling it that there is not enough ink in most of the cartridges, so I am stuck at this point. Removing the auto reset ink cartridge and then replacing it does not change the fact that the printer still sees it as almost empty since the auto reset cartridge will not go back to full until it thinks it is empty and is then removed and put back in. Is there a way around this so that the adjustment program will do the initial ink fill? Thanks. Share this post Link to post Share on other sites
John_Admin 386 Report post Posted March 22 Ink charge can be processed if printer has status - Ready to Print and ink levels are more than the 20% each color. Share this post Link to post Share on other sites
