Andre Arantes 0 Report post Posted April 8 Can someone help me? The l8050 boards are the same as the l18050. So I need to change the board firmware from L8050 to L18050 but I can't do it. I've already tried using adjota but without success and I tried using Wic reset, taking the eeprom from another machine and transferring it, it doesn't work. Has anyone already done this procedure? Share this post Link to post Share on other sites
wic.support 31 Report post Posted April 14 Good day. Those models use different firmware versions. Changin EEPROM will not accomplish anything and printer will not allow to flush firmware with different signature by software means. Your best bet is probably to remove chips from the motherboard and flush firmware dump with programmer (not firmware file that distributed with the updater, it has different format). Share this post Link to post Share on other sites
Andre Arantes 0 Report post Posted May 16 What would this chip be and the procedure? Share this post Link to post Share on other sites
wic.support 31 Report post Posted June 2 Unfortunately, we do not have this model so I do not know which chip exactly contains firmware data, we also do not have firwmare dump so you will need 18050 motherboard in the first place at which point it might me better to just replace motherboard altogether. Share this post Link to post Share on other sites
John_Admin 389 Report post Posted June 5 can we help you? do you have a question? Share this post Link to post Share on other sites
