khanmak
Is the new XP-4200 firmware compatible with XP-4205?
I'm not sure what the issue is on my end, but it doesn't work for my Epson XP-4205. It will attempt to install, but fail at 99%. I did mistakenly update it after buying it, but I'm not sure if that might be the issue or not.
On 9/13/2025 at 11:06 AM, Naddamon said:
fail at 99%
Follow step 3 - https://www.2manuals.com/product_info.php?products_id=2131
Pay attention on:
"...When Firmware Update process is complete - printer will restart - usually it will take only a few minutes but can continue for 10-20 minutes in some rare cases.  If process hangs or stops at 80-99% - replug power cable and start printer manually."
I'll keep trying. Halfway through it will reset on its own just like you say, then it says "Firmware version confirmed" from 85% to 99%. When it does fail, it just tells me to check if it is connected (it's connected with usb) and to check the power cable. But, I will keep at it.
