John_Admin 382 Report post Posted August 18, 2015 You can use WIC Reset Utility under Linux. Download Linux versions here - http://www.2manuals.com/WIC/linux/ 1. Differences between /dev/usb and /dev/bus/usb. In the Linux system same devices may be presented on the different levels of the /dev directory, each of them using different drivers stack. For example inkjet printer can be accesed from the /dev/usb/lp0 and /dev/bus/usb/002/004, but in the first case it's actually a printer (line printer 0) and in the second - generic usb device. WIC Reset will work only in the first case, thus creating aliases from /dev/bus/usb to /dev will not help to solve any problems and can be potentially harmful. 2. Access rights. Read me! By default access rights for /dev/usb/lp* are defined like this: ls l /dev/usb crw-rw---- root lp 180, 0 Oct 27 02:38 lp0 Thus only root and members of `lp` group can access the printer. There several ways to deal with this problem. 2.1. Add user to the `lp` group. The simplest way is to add current user to the `lp` group and then reboot: sudo usermod -a -G lp $(id -n -u) sudo reboot 2.2. Change access rights for single printer. Find our printer in /dev (for example, lp0) and then: sudo chmod o+rw /dev/usb/lp0 2.3. Run application as root: Warning! Running application using root account may be dangerous. You can use su, sudo or gksudo from gksu package. su wicreset sudo wicreset sudo apt-get install gksu gksudo wicreset When sudo is used system will not change user directory which may cause some warnings. On the other hand gksudo will always use root directory. In both cases all files created by the application will belong to the root, and therefore will be inaccessible by regular users. Also when application started using sudo or gksudo in KDE, GTK is unable to properly initialize all necessary resources. 2.4. Edit udev rules: You can change default access rights for the printer using device manager. For more details read udev manual page and this article: Writing Udev Rules by Daniel Drake. 3. Installation. You can install WIC Reset either from console or using package manager. 3.1. Installation from console. Install package using `dpkg` command from the directory, where package has been downloaded. Fix missing dependencies using `apt-get`. sudo dpkg i wicreset-i386.deb sudo apt-get -f install 3.2. Installation from package manager. Supported distirbutions: Ubuntu 16.04 Xenial Xerus. Debian 9.0 Stretch. Mint 18.0 Sarah. Derived distributions (Kubuntu, Xubuntu, Lubuntu, Edubuntu, etc.) should be supported as well. Compiler Version: GCC 5.2 Package Dependencies (dpkg-shlibdeps): C/C++: \libc6 (>= 2.17) libglib2.0-0 (>= 2.16.0) libgcc1 (>= 1:3.0) libstdc++6 (>= 5.2) X11 & GTK+: libx11-6 libsm6 libgtk2.0-0 (>= 2.24.0) libgdk-pixbuf2.0-0 (>= 2.22.0) Other: libcairo2 (>= 1.6.0) libpango1.0-0 (>= 1.18.0) libpangocairo-1.0-0 (>= 1.14.0) Screenshots: Share this post Link to post Share on other sites
Mat 0 Report post Posted May 13, 2018 Would it be possible to have wic reset for the latest version of ubuntu? The latest version is Ubuntu 18. Share this post Link to post Share on other sites
wic.support 29 Report post Posted May 18, 2018 Good day. Unfortunately, we unable to provide new version right now due to heavy refactoring in progress, but it may be possible to install current version of the package. First you need to download and install this package https://packages.ubuntu.com/xenial/libpng12-0 manually. Then install wicreset from command line like this: sudo dpkg -i --ignore-depends=libpango1.0-0 wicreset-amd64.deb Share this post Link to post Share on other sites
Cinders 0 Report post Posted July 20 Anything extra I need to know before I start this on my Linux machine? its been a few years since the last comment. thanks. Share this post Link to post Share on other sites
