WF-7720 CHIPLESS
0
16 posts in this topic
WF-7710DWF, WF-7711DWF, WF7720DWF, WF7721DWF
NOT FOUND :(
just activate the cartridge chips
https://chiplesssolutions.com/download/WF7710_FWG535TL_FA27HC.zip
0a.40.FA27HC
583436323036363142
D7MH6-RBF7Y-DH84K-Q28VY-QJXQX
Serial:X462066142
ID Code:
OjK6V5xCls99giq04g5BdoetAGOAcLnJVks3YipykXpyu2Tqgrh7kjE0RUKt7lir6jXlB4gTMMrWjiu9YrrBZbojkpGblhR44/mjwxJeBvhsGFRJc0/cVG3po6E61b915uXrz65sRJVMzKTOxBTEzoGOnpmAKiNQbOvaFAsiTtI=
Licencia en caso de actualizacion
kNj8LkMN+7lwJrVYlqFY8bNI8ukBAAAANgAAAN9bsuODo3EImAv5HAtTWFB1NQQAAQAAAHgAAAD6AAAA0QAAACC6GBBAALhzkwAU9P8gAMufMZUPlAAR9/8SAHpxnXBFmDAaAAAAAADA8f4JGroHcAAAAAAAAAAAiH15AgEAAAA=
the maintenance box is not active
Maintenance Box can not be reset or deactivated by firmware.
Chipless firmware is for making ink cartridges always full. Not Maintenance cartridge.
You can reset it by hardware Chip Resetter
hello dear, my problem, the maintenance box can't be reset with chip resetter when i do the chipless on epson wf-7720 and wf-2860 that i bought from u, i use the same maintenance box that i reset with same another printer without chipless and it's work good dear, need ur help as urgent
Hello dear, i forget to take the code  to restore the licence key that i bought from u. And if i make update the firmware, what can i do to re install again the licence key or i need to buy another licence to make it chipless again
regard
this is the licence for epson wf-7720 and wf-2860  that i bought from u
Dear,
Please use Your Activation Key:
 CTPT3-T978K-6MD7P-FFPJX-KJ3W2    - use before July 20
Printer epson wf-7720
I buy key activation for epson wf-2860 last week
 D9Q9X-T3JFM-B7FG2-XFKDM-BVWHC - expiration date - October 10
Regard,
To restore chipless firmware back after updating from epson - you need to have Recovery Code.
You have to save Recovery Code when using License utility
Incase you forgot to save your recovery codes, pls use wic reset program to save your  eeprom.
Then
you can reset it when printer has original epson firmware
so update it to epson firmware
reset chip
then uploads chipless firmware back again and restore your chipless eeprom
I have an urgent question regarding Epson reset keys.
They are valid, but cannot reset a printer.
Once you reset, it says key has been used to reset the target printer.
But in reality printer has not been reset.
My question is, could the keys be blacklisted?
in WIC utility - Menu - Support - Send report
send us report regarding your problem - we will check and reply
What do you mean???
0
