FutureScreen 0 Report post Posted August 12, 2019 Hi I purchased a firmware key for my Epson SC-P400 to install the no inks firmware. I went ahead and started the process and it started to flash and said it was complete on the computer, however the printer did not respond. After the power light flashing for a few minutes, the trash and ink lights snapped on orange which indicates a firmware error. I can't find any settings in the WIC utility to recover the P400 even in advance mode. There are options for the p600, I need to know how to pull the p400 out of recovery mode and I also need to get in contact with someone to reset my key so I can try to flash my firmware again. The printer is stuck in the MFP-IPL mode and is still able to receive inputs from WIC I just don't have the right recovery files to send to it. Thanks for any help Share this post Link to post Share on other sites
FutureScreen 0 Report post Posted August 16, 2019 My order number is #170204 if that helps reference my purchase Share this post Link to post Share on other sites
John_Admin 390 Report post Posted August 19, 2019 We have added P400 recovery firmware now to WIC utility So you can now restore firmware by WIC The same as here - Share this post Link to post Share on other sites
FutureScreen 0 Report post Posted August 19, 2019 Hi thanks for the response. I see on the windows version of the software the SC-P400 has been added as a recovery option. However I'm not sure if this is a glitch, it asks for a firmware key to use the recovery mode. When I used this feature last time for different model printer and in your video it does not prompt for key. Is this a bug from recently adding support? On the Mac version of the software there is no prompt for key, however there is also no option for the P400, please advise how to proceed. Share this post Link to post Share on other sites
wic.support 31 Report post Posted August 20, 2019 Good day. Recovery firmware has been fixed for SC-P400 and should be free now. As for the MAC, please, install latest version of the application and check again. 1 Share this post Link to post Share on other sites
FutureScreen 0 Report post Posted August 20, 2019 Hi thank you fo the help, the recovery mode was now a success. I still need to be put in contact with someone about resetting my key so I can try and flash the no inks firmware now, my printer turns on now though. What is the best way to get in contact with someone to help get this sorted, excited to not buy gloss optimizer. Share this post Link to post Share on other sites
wic.support 31 Report post Posted August 20, 2019 Good day. Your key F8...21 has been restored. Share this post Link to post Share on other sites
