John_Admin 393 Report post Posted December 2, 2019 NoInks Updater can be used to make WF-C5210, WF-C5290, WF-C5710, WF-C5790 printers chipless.Note!We don't support NoInks solution anymore. To make Your printer chipless - please use Chipless Solutions software. Find Your printers model and follow Step by Step Guide - ChiplessSolutions.com NoInks Updater can be used to make WF-C5210, WF-C5290, WF-C5710, WF-C5790 printers chipless. Download NoInks Updater here - NoInks Updater Download chipless firmware for model You need: WF-C5210 - download WF-C5290 - download WF-C5710 - download WF-C5790 - download Upload firmware to printer in the normal mode (i.e. just start the printer by pressing power button): Run EPFWUPD.EXE file and follow all steps until Firmware will upload in printer 100%. Press the OK button (for 5210, 5290) and CENTER of LCD (for 5710, 5790) - printer will turn OFF. Please check firmware version in Your printer. It should be now: WF-C5210 - CS26I9 WF-C5290 - CT14I9 WF-C5710 - CU26I9 WF-C5790 - CV14I9 Last step - use NoInks Updater: - power printer ON - run NoInks Updater - select printer model - input NoInks Key and press Update Printer and wait untill get message about success - save recovery file for future restore chipless firmware in case printer will update from Epson. You have now made Your printer chipless! For bulk orders - please contact us in Private Message or by LiveChatNoInks Keys doesnt have expiration date! Save Recovery File for using it in case printer will be updated from Epson. Disable automatic firmware update - read how After updating printer - dont forget to restart the printer!! Share this post Link to post Share on other sites
brutalrowdy 0 Report post Posted December 26, 2019 it says "update fail" Share this post Link to post Share on other sites
wic.support 31 Report post Posted December 26, 2019 Please, describe your actions with as much details as possible, also, please, try to update firmware one more time but this time in normal mode (i.e. same mode that is used for printing) and then use updater again. Also try following steps: 1. Upload Epson original firmware to your printer (update firmware from epson site) 2. After that - upload chipless firmware from our site Share this post Link to post Share on other sites
WePrintAsOne 0 Report post Posted January 29, 2020 Hi, newbie here. before i go spend some time and money with the whole process, just want to ask, once i do this successfully i will now be able to use my EPSON C5290 with Refillable Chipless Cartridges FOREVER, is that correct? Share this post Link to post Share on other sites
wic.support 31 Report post Posted January 29, 2020 Chipless firmware, once activated, do not expire and if you will acidentally update to official version in the future, you can restore it and reactivate with recovery code. Share this post Link to post Share on other sites
John_Admin 393 Report post Posted May 14, 2020 Matias37, 1. WF-C5890 - is not supported model. 2. For XP-241 chipless firmware - please follow Step by Step Guide - https://www.2manuals.com/product_info.php?cPath=107&products_id=1834 Share this post Link to post Share on other sites
