morris 0 Report post Posted May 2, 2021 my epson printer L1455 main board got spoilt, then i bought another one. the one i bought is recognized as Et 16500 series, but it starts in inspection mode, what can i do for the printer to start normally to start working again Share this post Link to post Share on other sites
wic.support 31 Report post Posted May 3, 2021 This most likely means that motherboard has not been initialized, you need to either write initial settings via ajp or find eeprom from another L1455 and write it to the printer. In both cases you will also need to set all other printer's settings again. Share this post Link to post Share on other sites
morris 0 Report post Posted May 5, 2021 thank you for your reply. how ever i realized the printer board is et 16500 model. is it possible to make the board start reading L1455 ? Share this post Link to post Share on other sites
wic.support 31 Report post Posted May 5, 2021 Both L1455 and ET-16500 use the same firmware, difference is in the data that located in the eeprom. So the answer stays the same, you either need to write initial settings or copy eeprom data from another device. Share this post Link to post Share on other sites
morris 0 Report post Posted May 6, 2021 thanks alot. worked fine with eeprom from another printer. the writing of initial settings is not active with tje adjustment programme am using. i dont know why Share this post Link to post Share on other sites
