chni 0 Report post Posted August 9, 2016 hi, i am trying this on an epson wf-7610 with firmware AD24G6. i get into the program update mode but then WIC does not recognize the printer anymore so i cannot select a firmware to update. the printer is connected via network. what can i do? Share this post Link to post Share on other sites
Colin 0 Report post Posted August 25, 2016 I just tried WicReset v3.75.90 and although my printer is supported it's not possible to downgrade my firmware at this time. Would it be possible to add this for my printer please and I would be happy to purchase if this worked My printer model is EPSON XP-432 Many Thanks Regards Colin Share this post Link to post Share on other sites
Tin Trinh 0 Report post Posted September 30, 2016 are yall gonna add support for xp410 firmware roll back?? Share this post Link to post Share on other sites
John_Admin 393 Report post Posted December 22, 2016 My printer model is EPSON XP-432 XP432 firmware downgrade is supported by WIC V5.0.11 version now. Share this post Link to post Share on other sites
and 0 Report post Posted May 14, 2017 I have an Epson Stylus SX400. Printer not recognize not original cartridge chips and CISS, now has firmware HR1183. Can you add firmware for this model? Thank you Share this post Link to post Share on other sites
bob bob 0 Report post Posted June 20, 2017 Will your program work on my xp-960? i need to downgrade the firmware. thanks in advance Share this post Link to post Share on other sites
John_Admin 393 Report post Posted August 2, 2017 Yes XP-960 is supported. See picture Share this post Link to post Share on other sites
Grg 0 Report post Posted October 28, 2017 I have an XP-530, i'm not sure, but it is possible that it has updated the firmware when i installed the printer ago. Now it has fw ver.:NR20H1 (20/01/2017) is it affected? I still use the setup cartridges, but I would like to know... Share this post Link to post Share on other sites
John_Admin 393 Report post Posted October 30, 2017 Does the printer work ok? Share this post Link to post Share on other sites
Grg 0 Report post Posted October 30, 2017 Does the printer work ok? Yes, no problems I did not have to replace the original cartridges yet. I just wanted to be informed. Share this post Link to post Share on other sites
Pato 0 Report post Posted January 21, 2018 I have made the firmware downgrade To an EPSON WF2750 printer once finished I got this message on the screen. EPSON ROM :IPLI NOT WR TABLE Then I turned off the printer and turned on again and no other message appeared on the screen and I can not do anything that I should do Recovery Mode Help me Please Urgent Share this post Link to post Share on other sites
John_Admin 393 Report post Posted January 31, 2018 For new printers manufactured in 2017 in China and some other countries this model WF2750 has unwritable flash memory - so this models will not be able to perform firmware changes. Sorry but it is made by Epson developers. Share this post Link to post Share on other sites
Suja 0 Report post Posted March 30, 2018 Hi I am having epson xp-235 printer.does firmware dowgrade work on this printer?. Share this post Link to post Share on other sites
dpar 0 Report post Posted June 14, 2018 is Epson xp-830 downware available? Share this post Link to post Share on other sites
John_Admin 393 Report post Posted June 16, 2018 XP-235 and XP-830 firmware downgrade is available Share this post Link to post Share on other sites
uruguayo 0 Report post Posted July 12, 2018 Hola, alguno habla espaГ±ol? Quiero saber algunas cosas para hacer donwgrade al firmware de TX730WD Saludos. Share this post Link to post Share on other sites
John_Admin 393 Report post Posted July 13, 2018 TX730 is supported by WIC and You can make firmware downgrade Share this post Link to post Share on other sites
uruguayo 0 Report post Posted July 13, 2018 TX730 is supported by WIC and You can make firmware downgrade Hola John. Lo se, ya tengo instalado el WIC e intente empezarlo a usar, pero pese a haberle cambiado el idioma a espaГ±ol me tope con que esta en ingles (no esta completamente traducido). Por eso necesitaria ayuda de alguien que hable espaГ±ol (no soy bueno con el ingles). 1) Al empezar a usarlo me dio error ya que no hizo nada, pero no marco el numero de error. 2) el downgrade del firmware es al original anterior de la maquina de fabrica? O a una version de firmware modificado. Esto dado que luego de bajarle el firmaware quiero poder volver a usar el adj prog. para borrar los contadores. 3) Se puede hacer el downgrade con el sistema continuo o debo comprarle cartuchos originales para hacer ese proceso?? Agradezco respuesta en espaГ±ol ya que con traductor hay palabras que cambian de sentido al hacer la traduccion. Saludos y mil gracias por responderme. Share this post Link to post Share on other sites
xenocracy 0 Report post Posted October 2, 2018 Search the Original Firmware for my Printer Epson XP-342 as .efu ?! JU16H6 - 16-06-2017 Have: FWF730TL_JU23I2.exe FWF730TL.efu (zip) -> FWF730TL.rcx Have Flashed XP-342 JU16H6 No Inks Firmware Have only found the Original Firmware from Them. XP-342.JU23I2 Please can You give me the Original Firmware to me ? Thank You an Endconsumer. Share this post Link to post Share on other sites
nicolasc 0 Report post Posted October 14, 2018 Hi, I bought two keys to reset printer xp- 445 firmware. The first one i bought wasn't dedicate to firmware, so i waste 10 euros ! The Second one was a specific one to update firmware... but once it finished to download i have this message : Please don't tell me i spent 17 euros for nothing !!! Or in that case please Just pay back !!! Share this post Link to post Share on other sites
djgavias 0 Report post Posted November 19, 2018 hello i buyed a firmware key to downgrade epson wf7110 the printer after program sent the update blinked error light and don't updated now i spent the key any solution? Please. Model wf-7110 series firmware version AS01E8 01/08/2014 Share this post Link to post Share on other sites
djgavias 0 Report post Posted November 21, 2018 the support chat help me trought, thank you LISA Share this post Link to post Share on other sites
Ramadhan 0 Report post Posted June 6, 2019 I have followed all the steps for downgrading WF 7710 but it still prints blank pages and the reset key is not working anymore. What Do I do? I need URGENT ASSISTANCE.I have bought all three keys because I don't know why it's not working and none of the three keys is helping my situation. Share this post Link to post Share on other sites
wic.support 31 Report post Posted June 6, 2019 Good day. First of all Chipless Solutions keys and License.exe are used to make printer chipless and could not fix any other porblems. Futhermore I doubt that this problem is actually related to the firmware and can be fixed by firmware downgrade. If you want to perform firmware downgrade anyway you need to use WICReset application. Share this post Link to post Share on other sites
Ramadhan 0 Report post Posted June 7, 2019 The problem with printing blank pages started immediately after the firmware update. I consulted and was advised to perform a firmware downgrade and it would solve the issue . If it's not the firmware issue, could you know what the issue is and how to fix it? Share this post Link to post Share on other sites
