John_Admin
Epson Printer Chipless - No Chips Firmware
New WIC Reset Utility has availability for some printer models to make them Chipless.
What does it mean?
Printer will show 100% ink level all time you use it.
You can get out ink cartridges or just IC Chips and printer will print as usual.
Once You change printers firmware to Chipless Firmware - the printer will not need to reset ink cartridges, printer will not need to use Auto Reset Chips or CISS Chips - no one type of ink cartridges chips will be required anymore!
Supported models:
WorkForce WF-7610/7611
WorkForce WF-7620/7621
WorkForce WF-7110/7111
WorkForce WF-2750/2751
WorkForce WF-2650/2651
WorkForce WF-3540/3541
WorkForce WF-3620/3621
WorkForce WF-3640/3641
WorkForce Pro WF-4630
Epson Workforce WF-5620
Epson Workforce WF-5110/5190
Epson Workforce WF-6090/6093
Epson Workforce WF-8010
SureColor SC-P400, SC-P407, SC-P408
SureColor SC-P600, SC-P607, SC-P608
SureColor SC-PX5V2
PX-M5040F
PX-M5041F
PX-M741F
PX-S840
XP-243, XP-245, XP-247
XP-330
XP-342, XP-345, XP-347
XP-600/601/605
What do You need to do that?
1. Latest WIC Version utility.
2. Printer, supported by WIC and with chipless firmware availibility. For example WF3620 -
3. Windows OS or MAC OS computers.
Lets start.
1. Connect the printer by USB cable to your PC and run WIC utility. Disconnect all other printers from Your PC.
2. Click on Change Firmware Version button.
3. Put printer in Firmware Update Mode by folowing instructions for this printer model.
After You put printer in Firmware Update Mode it will indicatede like MFP-IPL - please pay attention on it.
4. After that You have to open Firmware Versions with Disabled ink Cartridges drop list and select printer model you have connected.
5. Enter Firmware Key and press OK.
6. Wait untill confirmation message appear.
7. Switch OFF the printer and switch ON again.
That's all. Now Your printer will not require any ink cartridges.
Thus You can use Ink cartridges, Refillable Cartridges, CISS or other cartridges You want.
Printer will never stop because of "ink finished" error or "not original inks" error.
Download latest WIC Version here - http://www.2manuals.com/product_info.php?products_id=1149
Buy Firmware Keys to make Printer Chipless - Buy Firmware Key
Have questions?
Please cantact us by Live Help or here in this thread.
@John_Admin One question, i have wf-7610, but the chipless fw version is "default", please define default?, Is the first firmware from epson?, because older firmware haves bugs on fax & scan features.
After chipless update can i update normally printer to latest?
19$ is expensive for an old firmware, better with arc chips.
Can I reuse the same firmware key on same machine 2 times?? for example upgrade to chipless > upgrade latest > reupgrade to chipless?
Thanks.
Help - I can't downgrade Firmwareusing WIC.
In SC-P400, original firmware no recognise resettable
cartridges.
Older firmware working, but I can't change it anyway.
I lost money, 4 WIC keys, without results.
Where is the problem?
My e-mail
audio@audioexpert.com.pl
Wlodzimierz
cartridges.
My e-mail
Wlodzimierz
Hi,
have a question inadvance to buying the chipless firmware for Epson WF-7610:
What firmware version is it based on, and do I loose other funcionality with this special firware?
Thanks!
Thanks.
Hi
what did you do about this?
Plz pm me about it
I have the same situation as you
Hi I have a really important question @John_Admin
I have a wf-7610, but the chipless fw version is "default", please define default?
Is the first firmware from epson? or what version?
I'm really waiting for your reply
We have other chipless solution for many new models:
https://www.2manuals.com/index.php?cPath=107
Supported models:
XP-55, EP-306
XP-230, XP-231, PX-048A
XP-235
XP-240, XP-241
XP-340
XP-430, XP-431
XP-440, XP-441, XP-446
XP-442, XP-445
XP-630, XP-635
XP-640, XP-645
XP-760
XP-830
XP-960
XP-6000
XP-15000
WF-2630, WF-2631
WF-2650, WF2651
WF-2750, WF-2751
WF-2760, WF-2761
WF-3720, WF-3721, WF-3723, WF-3725
WF-4630
WF-4720, WF-4730, WF-4734
WF-7710DWF, WF-7711DWF, WF7720DWF, WF7721DWF
WF-C869R
WF-C5210, WF-C5290
WF-C5710, WF-C5790
EP-808
EP-979A3
SC-P400, SC-P407, SC-P408, SC-PX7V2
SC-P600, SC-P607, SC-P608, SC-PX5V2
SC-P800, SC-PX3V
Download chipless Firmware here - http://chiplesssolutions.com/download.shtml
Hello
Who knows if wf-7120 will be supported by chipless solutions because I need to import ciss for this printer and don't know if I purchase them with chips or no?!
Please help me, tutorial detail downgrade firmware IC disable epson P607?
Downgrade firmware epson p607 successfully, but when I remove the cartridge the chip remains cross (unreadable)
