Pabloalbo1991 0 Report post Posted March 15, 2020 Hello, can you help me, printer does not load says reading failed 1 Share this post Link to post Share on other sites
John_Admin 373 Report post Posted March 15, 2020 Upload firmware in normal mode dont put printer in Firmware mode then use your key Share this post Link to post Share on other sites
Pabloalbo1991 0 Report post Posted March 16, 2020 I have the solution for reading failed -1 problem 1.- Put the printer in recovery mode. To put in recovery mode you must load the firmware and when I start writing the printer you turn it off before it finishes. 2.- When in recovery mode, upload the firmware to the printer from your pc. When charging is complete, the printer will turn itself off. 3.- You turn on and apply the activator "license" and voila !!! It works perfectly ..... I hope it works for you !!! any questions write me .... Share this post Link to post Share on other sites
Hamset 0 Report post Posted April 9, 2020 We use the method without service mode and it reaches 14% then it sends an error indicating that the firmware is not installed. Share this post Link to post Share on other sites
wic.support 21 Report post Posted April 9, 2020 This means that either USB cable is damager or more likely, that printer has some error (for example ink out error). Unfortunatelly, for some models update process is only possible if printer is ready to print (i.e. it does not show ink out error or any other errors at all). For such printer recognizable ink cartridges or suitable alternative must be installed while it is updating. If it is not possible, you may try to update it first using service mode and if it fails, try this method. The affected printers are: XP-211 XP-212 XP-213 XP-214 XP-216 PX-046A XP-230 XP-231 XP-235 PX-048A XP-430 XP-431 XP-434 Share this post Link to post Share on other sites
