Dabany_DB 0 Report post Posted October 20, 2019 Hi guys I have an Epson and I made it chip-less, but After an update during install drivers on computer my device says (install ink Supply unit correctly) and when I was want to use recovery key the licence program detect the printer but did not read it , I think it don't receive the Firmware because the when i update firmware the firmware version doesn't display on screen the version is 16.54 but the printer shows 16.56 i mean it's difference anyone can help? thanks? Share this post Link to post Share on other sites
wic.support 31 Report post Posted October 21, 2019 Good day. Please, try reupload chipless firmware in the service mode first. 1 Share this post Link to post Share on other sites
John_Admin 393 Report post Posted October 28, 2019 We have updated firmware - please download it here - https://chiplesssolutions.com/download/WFC5710_FWG239TL_ZZ99Z9.zip Upload firmware to printer in normal mode - dont put printer in Program Update mode. The uploading process will stuck at 70-80% - it is ok! Open task manager and stop updater process. Printer will blink for about 5-15 minutes - then will power OFF. Now power on the printer - chipless firmware is installed now in your printer! Please reply about results. 1 Share this post Link to post Share on other sites
Nabil 0 Report post Posted October 30, 2019 i have other problem in this wf-c5710........ the problem is sometimes cutting the printing on text and sometimes double printing on same text Share this post Link to post Share on other sites
John_Admin 393 Report post Posted October 31, 2019 Reinstall printer drivers Share this post Link to post Share on other sites
Nabil 0 Report post Posted October 31, 2019 JUST reinstall drivers? ......but when install driver i am afraid the update will lock chipless ..its right? Share this post Link to post Share on other sites
wic.support 31 Report post Posted October 31, 2019 Do not install epson update center, only driver and also disable updates in the driver and on the printer itself (in the menu), anyway, even if you accidentally update firmware you can reactivate chipless mode by installing chipless firmware again and using recovery code (provided that you saved it during activation). 1 Share this post Link to post Share on other sites
Haldur 1 Report post Posted November 8, 2019 "i have other problem in this wf-c5710........ the problem is sometimes cutting the printing on text and sometimes double printing on same text " Hello John i have the same problem too . Reinstalling driver isnt solving it. i tried all drivers , universal, postscript also different models drivers. none of them working Because its not about the driver. its about the chipless firmware. With original firmware in standart speed mode its working fine. But when we change the firmware to chipless in standart speed mode it writes double time on same text. if you change the speed mode to high quality it stops. but this time its too slow maybe 5 pages a minute, everybody complaining about it. When you make speed fastest the doubling stops but this time colors and blacks are very very faded nobody accept this colors. i think you are changing a small wrong part at the firmware. İhope you solve it because its directly affecting our business. we had to change machines with wf-6590 and there is no chipless solution for them Share this post Link to post Share on other sites
Dabany_DB 0 Report post Posted November 8, 2019 Thank you, for all of you , i appreciate your helps Share this post Link to post Share on other sites
John_Admin 393 Report post Posted November 9, 2019 Haldur, It is common problem for wf-c5710 printer when it works with not original ink cartridges I mean if you use Auto Reset chips or One Time not OEM chips or modified firmware. Share this post Link to post Share on other sites
Nabil 0 Report post Posted November 9, 2019 thank you sir .... could we find update chipless firmware without printing problems???? Share this post Link to post Share on other sites
John_Admin 393 Report post Posted November 10, 2019 I am not sure Sorry Share this post Link to post Share on other sites
Nabil 0 Report post Posted November 11, 2019 Dear Sir i would like ask you if you have new update frimware for WF-C5210 like a bellow frimware but for WF-C5210 since can not pass through to the activation screen (read failed-1) We have updated firmware - please download it here - https://chiplesssolutions.com/download/WFC5710_FWG239TL_ZZ99Z9.zip Share this post Link to post Share on other sites
John_Admin 393 Report post Posted November 14, 2019 Updated WF-C5210 firmware- http://chiplesssolutions.com/download/WFC5210_FWG242TL_ZZ99Z9.zip Share this post Link to post Share on other sites
armsroom 0 Report post Posted November 26, 2019 It is common problem for wf-c5710 printer when it works with not original ink cartridges. ---------------------------------------------- Hello, John Is it common problem for WF-C5790, too? I've just bought one. Share this post Link to post Share on other sites
John_Admin 393 Report post Posted November 26, 2019 we have no one customer with such problem in 5790 Share this post Link to post Share on other sites
Nabil 0 Report post Posted November 30, 2019 HELLOW i would like ask you .... whats deferment between 5710 and 5790 ???? Share this post Link to post Share on other sites
wic.support 31 Report post Posted November 30, 2019 They use different firmware versions, incompatible to each other. Share this post Link to post Share on other sites
Nabil 0 Report post Posted November 30, 2019 about WF-C5210 HOW solution for this error code 1 0X67 could you support about the problem? Share this post Link to post Share on other sites
wic.support 31 Report post Posted December 1, 2019 I can provide error description: 0x67 I/S motor PID reverse error. Possible causes: Operation failure of the I/S motor. The ink system was stopped. Mechanism overload. Broken gear or encoder error. Disconnected or broken flexible flat cable. Main board failure. I/S motor used for driving the pump of the ink system unit. PID means proportional–integral–derivative controller. Unfortunately, I do not have any specific advice, you need to fix this error yourself using service manual or bring the printer to the service center. Share this post Link to post Share on other sites
Nabil 0 Report post Posted February 8, 2020 hi please let me know if there is new firmware update for 5710/5210 thank you and best regards Share this post Link to post Share on other sites
Nabil 0 Report post Posted February 28, 2020 hi team how are you please let me know how i can check the chipless, if not work Share this post Link to post Share on other sites
John_Admin 393 Report post Posted February 28, 2020 What is your Order number?? Share this post Link to post Share on other sites
matjaz 0 Report post Posted April 15, 2020 Hi, Jonh i have the same problem: after chipless solution with your firmware and noninkupdater printers (wf 5710) stops printing or or start double printing on same text i think you are changing a small wrong part at the firmware The problem ocure after updaeting with your key. i have in my warehouse 50 pieces wf 5710 which are now useless if we can not fix these problems. I am renting printers. please replay what to do. Share this post Link to post Share on other sites
armsroom 0 Report post Posted April 21, 2020 matjaz printers (wf 5710) stops printing or or start double printing on same text -------------------------------------------------------------------------------------------------------------------------------- To matjaz and John Wf-C5710 The Problem always happens at Following 3 conditions ; 1. 2-sided printing & 2. Multi-page (2-up) option & 3. Standard Quality -----------if you change just one option, it will not happen often--------- I hope that I can get Fixed firmware soon. Share this post Link to post Share on other sites
